Sa200 Won't start
发表于 2021-12-28 15:51:28 | 显示全部楼层 |阅读模式
Iv got a sa200 I believe  is a 79 model. It won't start without being jumped off. The battery has 11.5 volts and new alternator, it won't even try to start unless it's being jumped. Aldo it won't idle up not sure if that has something to do with it to. Any help I'd appreciate
Reply:That battery should read about 12.3 volts. 11.5 is too low. Can't help with the idle problem. Check the voltage while it's running, it should read about 13.5- 14.0Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
GMT+8, 2025-12-19 11:54 , Processed in 0.090979 second(s), 18 queries .
