Tigging thin sheet steel
发表于 2021-12-28 15:51:28 | 显示全部楼层 |阅读模式
Hi,I consider buying a cheap chinese tig-welding inverter, which has a 5 to 200 Amps range.I want to weld thin automotive steel, thicknesses will be in the gauge range 11 to 22.That machine has no pulse capability (which is said to be good for thin metal).Can I expect the welder above will tig that thin metal on it's lowest A- settings, or willpulse absolutely be needed to avoid burning holes?Yes, I am aware Lincoln, Miller, Hobart and many great makes are to be preferred, butI -sadly- can not afford these..Thank you,oldwelderman
Reply:You can also pulse using your peddle, vary the current flow. Takes practice.Retired - Refrigeration Pipefitter - Master Electrician-  IowaLots of Hobbys
Reply:The only thing that might be detrimental is the hot-start.  Even with a low low-end of 5A, if the hot-start is too high (or lasts too long) it is possible it could blow holes.
GMT+8, 2025-12-19 11:54 , Processed in 0.093076 second(s), 18 queries .
