Should tungsten sharpening discs be specific for the metal?
发表于 2021-12-28 15:51:27 | 显示全部楼层 |阅读模式
Is it necessary to use different tungsten grinding wheels for different tungstens?I have dedicated wire stainless brushes for steel and one now for aluminum…..
Reply:I've run pure, lanthanated, thoriated, E3, ceriated and probably something else over the same section of belt sander and never had a problem.  I only use the belt sander for tungstens and nothing else (it's a cheapie).  I do make sure to run each tungsten over a different section of the belt for a few seconds to get off anything big, then switch to the dedicated section.  It may not help, but it doesn't hurt.Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
GMT+8, 2025-12-19 11:56 , Processed in 0.092509 second(s), 18 queries .
