Plasma Cutter Project,, WhAtSyOuRgUeSs ??
发表于 2021-12-27 15:51:20 | 显示全部楼层 |阅读模式
OK, the gift wrapping, and unwrapping is over,, and I ate too much,, AND the weather is beautiful this week!!I figure it is time to start a project,,I haven't done much with the plasma cutter I bought this past summer,, so this project will be plasma cutter intensive,,The oil tank I was given is an indoor tank, that was used outdoors,, so, the bottom of the tank resembles a screen door.That does not hurt the project,,The plus side of the bottom being rusted away,, there is nothing combustible inside of the tank!! That all drained, or evaporated a decade ago,,So,, what is your guess as to what I am going to try to make out of this 275 gallon fuel oil tank  ??
Hint as to what it is,, I have never seen one this large before, and I watch a LOT of YouTube videos!!
To start, an end was "precisely plasma cut"
  maybe, I should say, "plasma cut,, good enough"
Make your guess,,, please,,
Reply:The plasma took me a while to get good at. I've self tought myself to move as fast as you can before it kicks back and that's what ruins the tips. I do it by ear a lot too it has a certain sound when its at it's fine line of too fast go much faster and it  will kick back. Really fine line between to slow and too fast. Being light handed it the key
GMT+8, 2025-12-19 11:54 , Processed in 0.094300 second(s), 18 queries .
