Mobile Radio Antenna Base
发表于 2021-12-26 15:51:24 | 显示全部楼层 |阅读模式
So this is a base for a large antenna that gets used for FEMA deployments to disasters where a base station needs to be established during a possible grid failure/major disaster etc to cover a large area.A car or truck tire gets parked on it for ballast. They asked me to replicate it, to which I asked if I can change the design so it doesn’t need a bunch of silly pins. So this is what I came up with, it’s all 1/4”. Waiting for final approval on the design to start the build. Should be a couple hour project.
www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:Zach, how big is the antenna (or what frequency band is it) and how long of a mast will plug into the yellow section? I recently bough an antenna for my ham radio that tilts over, but the design seems a whole lot simpler. this is a 43 foot mast, so it might be overkill. The tilt plate and mast are aluminum, the hardware is stainless. See below:
Miller Multimatic 255
Originally Posted by shortfuse
Nice, simple design.  That mass of pins was a mess.  I would, however, attach a small chain from the mast holder to the pull pin with the ring in it....that will be the first thing that gets lost, I guaraaaannnnteee!
GMT+8, 2025-12-19 11:54 , Processed in 0.096187 second(s), 18 queries .
