Substitute for MM80FU30 Diode
发表于 2021-12-22 15:51:18 | 显示全部楼层 |阅读模式
Guys please suggest which diode should i use instead of MM80FU30, as these are not available at my end
Reply:Need more data Voltage and amperage?Dave
Originally Posted by wmgeorge
Its a Mosfet TO3 mounting and is this a Chinese welder by some chance?  This is the only Link I found and I know ZERO about these folks so order with care.  I have in the past ordered direct from China via Hong Kong for Samsung TV parts!!  Pay with PayPal and use DHL my parts came from a different seller but were in my hands on the third day!!  Here is the Link, proceed with care > https://www.transistorfet.com/transi...earch=MM80FU30
Originally Posted by Louie1961
I have a feeling it is not a mosfet but rather a pair of fast switching diodes with a common cathode connection (fast recovery epitaxial diode or FRED)
Reply:I did, but I also gave the OP the benefit of the doubt and found this diode. https://www.alldatasheet.com/datashe...80FU040PC.htmlAm I willing to bet my life on it? Nope, but the FRED makes a LOT of sense if it goes into an inverter welder.Miller Multimatic 255
Reply:Makes no difference I hope what we found helps. Does he have a place to order what you found?  Yours is not the same part number?
Reply:yeah alibaba and others are thick with them at around $0.50 per piece, unless you buy in bulk, then they are down to $0.22 per unitMiller Multimatic 255
Reply:Guys yes it's a Chinese machine,  IGBT 320AmpAnd yes that part is a Diode400v 80ARoHS compliant.(mm80fu040pc) this was the name i found on the web.Last edited by Mksince98; 5 Hours Ago at 10:46 PM.
Reply:So which number is correct???
Reply:This is a welding machine?Dave
GMT+8, 2025-12-19 11:54 , Processed in 0.067578 second(s), 18 queries .
