Anyone made a kindling splitter?
发表于 2021-12-21 15:51:20 | 显示全部楼层 |阅读模式
Looking for some design ideas for a kindling splitter. Want to be able to put a normal size piece of firewood in, whack it with a hammer, and get some nice small kindling pieces out. Any ideas?GlenHobart Champion 16Miller XMT 304 CC/CV toastedHobart Hefty CC/CVHobart Handler 140Lotos LTP5000D
Reply:Toss the hammer on the scrap pile, and build a spring wood splitter.It will work 5X faster, and 10X easier than a hammer separate splitter.Here is a 1 minute video, see how much splitting occurs in one minute
Reply:Here is another video,,This one operates MUCH slower,, I think it is slower, because the guy is older,,,
Reply:I've made 5 kindling splitters like these.  Stole the idea off the entrynet, LOL.Frame is all 1/4" mild steel bar stock, blade is leaf spring, not heat treated (the spring steel is hard enough to split without heat treating).  I bent the circles with forge and bending jig and welded closed.  If you have any scrap oxy cylinders laying around, just cut slices from them.  I made the first three from cylinder cuts, the last ones by bending the 1/4" bar.  I posted pics somewhere here on the forum, just too lazy to look for the post.
Measurements
Reply:That is a cool setup SweetMK, but doesn't look practical (or safe) for making small kindling pieces.Shortfuse, that's the type of thing I was looking for! Thanks for the details. Have you experimented with multiple blades at all? Just thinking it would be convenient to make say 6 pieces at a time instead of two.I did a search for kindling splitter on this forum but didn't chase it far enough I guess...GlenHobart Champion 16Miller XMT 304 CC/CV toastedHobart Hefty CC/CVHobart Handler 140Lotos LTP5000D
Reply:Following this design should be easy
https://www.kindlingcracker.com/
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Whatever you use NEVER,EVER hold the wood with thumb, fingers or hand on top! Too much room for error.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Originally Posted by shortfuse
What do you mean by multiple blades? Interchangable or just when fabricating more than one splitter?  Not clear on what you are asking.
Reply:No, I have not explored multiple splits/blades.  That's a good idea, though.  Now that he has a model to go by, I'm sure he could come up with a design that could spin off of mine and mount more than one blade.  I think I'll also look into how to do that.ArcTan, you may have planted a seed idea!!
Reply:Geeze,You city slickers sure are fancy…I don’t use much kindling wood since the stove is going pretty much 24/7 during the winter months.  But on the occasion that I need some,This little bugger does a fine job.  .
Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:I made the hammer a couple years ago when I was giving Moto welding lessons.  .
Reply:I gots some hammers like that.
Reply:Speaking of hammersHere’s another one I have for special occasions.  One shiny penny if you guess what it’s for.
GMT+8, 2025-12-19 11:53 , Processed in 0.068360 second(s), 18 queries .
