Patio Chair Repair
发表于 2021-12-21 15:51:20 | 显示全部楼层 |阅读模式
My daughter has four chairs on her back concrete patio.  The chairs have a 21” ring on the bottom of the pedestal as shown below. The rings on two of the chairs were badly rusted, so I decided to repair them.  1. Chair to be repaired
The other two of the four chairs look like they are brand new.  I am not sure why this is the case, considering that they are all in what appears to be the same environment.2. Top view of chair base
3. Bottom view of chair base
4. Rust on bottom 1
5. Rust on bottom 2
Smith Oxyacetylene TorchMiller Dynasty 200DXLincoln SP-250 MIG WelderClausing/Coldchester 15" Lathe16" DuAll Saw15" Drill Press7" x 9" Swivel Head Horizontal Band Saw20 Ton Arbor Press BridgeportLincoln LE  31 MP & Lincoln 210 MP
Reply:6. Rust on bottom ring
I decided to use a ring roller to manufacture the new ring.  I decided to roll the ring from one piece of 7/8” diameter tubing with a .083” wall and a 21” ring OD. Notice that the idler rollers are in the furthest out position.7. Me starting to roll ring
Notice that my friend John has the idler rollers moved closer by two positions. This is necessary to get the desired diameter of 21”.  8. Rolling the completed ring
9. Me cutting scrap from ends of ring
10. Me welding ring together
Reply:11. The completed ring weld
12. Weld ground and polished
Before rolling the ring for the second time we straightened out the ring. (To make it planer)13. Straightening ring
We decided to roll the ring a second time to help to make it rounder.14. John finishing rolling the ring
15. Coping the chair legs
Reply:16. Welding one leg
17. Welding another leg
When I notched the foot, I left two flats to help me to hold the foot for the counter boring operation.18. Notching foot
I left a scrap piece of 7/8” stock in the Jacobs Rubber Flex chuck as a stop for the foot that I was counter boring. 19. Drilling foot
20. Counter Boring foot
Reply:Nice job. Fiddling is my favorite sport. lol I bet you made your daughter smile, and that makes it all worth it.
Lincoln 330 MPXModified TombstoneLincoln LN-25X-TVTMagnum PRO 250LX GT Spool Gun¼ Ton of Torches OFC-A / OFG-ASMAW FCAW GMAW Air Carbon Arc Gouging#Freebird Welds
Reply:21. Two feet done
22. Painted and feet mounted
23. All done
-Don
Reply:I love fixing stuff like that…but you got tools I do not have…nice repair OP.You have turned 50 dollar chairs into 438.23 chairs!
GMT+8, 2025-12-19 11:55 , Processed in 0.096252 second(s), 18 queries .
