Federal Pacific Breakers
发表于 2021-12-20 15:51:19 | 显示全部楼层 |阅读模式
Hi.  would  anyone where I could  find  any  Federal  Pacific  stab  lok  breakers I  would need  a  70 amp  2 pole   But there  is  nothing  new  here in  Canada   I see a few used ones on  e  bay   But that seems like a   risk  to  take.  Thanks  for   any  information  anyone  could  give  me
Reply:https://www.allelectric.com/blog/201...it-breaker-pa/Mike
Reply:https://sandiegoelectricalsupplies.com/san-diegoThey have everything. I’ve been in a bind on old panels and they buy used breaker so they should have what you need
Reply:Thick or thin style? I see the thick ones on Amazon.ca, but not the thin. 70 amp is a bit of an odd size. I've retired a box, but it had 100 amp main. https://www.amazon.ca/Connecticut-El...l%2C112&sr=1-2Given Leight's post, it might be a good time to consider a new box... if you can get one. I know my electrician was having problems last summer.Last edited by whtbaron; 4 Hours Ago at 11:16 PM.The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Thanks  for the  replies.  the  breaker is for the furnace.   And  it  is  the  thin  type.   70 amp I could go  with the   100 amp  if  they  would  fit  the  space    Thanks.
GMT+8, 2025-12-19 11:55 , Processed in 0.093579 second(s), 18 queries .
