Does anybody make a decent round soapstone holder???
发表于 2021-12-19 15:51:31 | 显示全部楼层 |阅读模式
I've tried several.  I've been through a few of the Wypo brand with the brass body and nut on the back and the no-name "Made in USA" in aluminum with the nut that tightens on the front.  They all slip.  Anybody found a good one?
Reply:They use to make good round holder.But cost was high for round so back to rectangular and silver pencil lead rectangular for fine work.Dave
Reply:Looks like a market opportunity for you...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Originally Posted by M J D
I've stopped using using round soapstone ( and pretty much flat also) one of the reasons being the POS holders. Pretty much just use the " silver steak" mechanical pencil. What I did do before using the silver streak was to put a piece of heat shrink tubing over the soapstone and treat it like a wooden pencil.
Silver streaks are a whole other rant.  The standard silver streak mechanical pencil never seems to hold up for long and then I lose the little silver cap.  I’ve also been through 2 of the fatter “Pro” versions and they both stopped feeding after after the third refill.  I really like the line a silver streak makes but also run into holder issues…
Reply:I just use the flat soapstone about 3" long and keep sharpening it on the side of the bench grinder wheel. When it gets too short I file 13 it and start over. Carbide scribe works good on shiny stuff.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Couldn't pay me to own a mechanical pencil.  I hate 'em.For over 20yrs I've used a silver art pencil.  They work great EXCEPT that the damn lead always breaks, or small sections simply fall out of the end of the pencil body.LWS recently switched to a "welders pencil" from the art pencil, which I'll probably find to be just as bad at shedding the lead............but maybe not(shrug).  I guess I'll find out the first time I use one.  Got a bunch of the old pencils to work through first.They all suck, but if you need a fine, and accurate line, there's no substitute.
  Cost about 75 cents apiece  I think.
GMT+8, 2025-12-19 11:52 , Processed in 0.094755 second(s), 18 queries .
