Air operated slag peener
发表于 2021-12-19 15:51:30 | 显示全部楼层 |阅读模式
Going to be doing an MSD Shear soon at work. Says this tool must be used. Is it true? How is it done most commonly? Any tips?
Reply:A pic of said tool would help.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:For peening a weld an air chipping hammer works better. Had to weld up a crack in a manganese crusher roll with 7/32" Nicromang and had to peen every pass else the manganese would crack alongside the weld.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I've been using needle scalers and air hammers (using the pointed attachment). for years. Hit it quick and clean, weld and repeat.Lincoln 330 MPXModified TombstoneLincoln LN-25X-TVTMagnum PRO 250LX GT Spool Gun¼ Ton of Torches OFC-A / OFG-ASMAW FCAW GMAW Air Carbon Arc Gouging#Freebird Welds
Reply:I like using wire wheel on 4" grinder. But I was had to pay air compresser so running a grinder off welder was lower cost. Did use hammer too.Dave
GMT+8, 2025-12-19 11:54 , Processed in 0.100036 second(s), 18 queries .
