Please recommend
发表于 2021-12-15 15:51:21 | 显示全部楼层 |阅读模式
Please recommend suitable model MIG/MAG welding machine. Approximate specifications isConstant Voltage 600 amps water cooled MIG/MAG power source with manual parameter selection fitted with Suitable wire feeder can feed 0-40 meter/ minutes. 4 roll drives (knurled) 3 metres long 600amps MIG/MAG welding torch.Lincoln, Miller, OTC, Kempi, Esab
Reply:You've kind of answered your own question there? As you know what you want
Are you welding steel with flux core? If so, I recommend a 5 meter torch, far more flexible than 3m and with a quality 4 roll feeder set up right, you'll never have any problems.Multiprocess inverter? Or just pure CV? Do you need hot start/crater fill?
Murphy's Golden Rule: Whoever has the gold, makes the rules.
Reply:I would buy a WIA welaric 500i, because I'm Aussies, and they're an Aussie company (although not Aussie made anymore) and I've burned just a few rolls of wire through one and it's a nice reliable machine and a great price, 5.5k Aus, so that like 3.9k USD at the current exchange rate
Reply:I was happy with a Miller 750 amp.Dave
Reply:As much as I shy away from ESAB, they have the goods.750 amps at 100% duty cycle. https://www.esabna.com/us/en/product...750i-cc-cv.cfm
Couple that with a DF Machine Specialties water cooled torch system and away you go. https://www.dfmachinespecialties.com...led-mig-pistol
Last edited by shovelon; 8 Hours Ago at 07:06 PM.Weld like a "WELDOR", not a wel-"DERR"
MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2025-12-19 11:54 , Processed in 0.071867 second(s), 18 queries .
