Miller bobcat 225 Spec H
发表于 2021-12-14 15:51:20 | 显示全部楼层 |阅读模式
If I leave this outside and it rains it’s getting a little water in the gas tank and it runs bad until I pump the bottom part of the fuel tank in a bucket and hook the hose back to the carb then it runs fine. Could it get threw  in the small hole in the gas cap vent? I’m trying to find a leak in the tank also. I’m going to pull the tins and fill the tank all the way to the top and maybe I can see something.
GMT+8, 2025-12-19 11:53 , Processed in 0.097413 second(s), 18 queries .
