Remove porcelain knob from an old ARROW HI-MED-LOW-OFF switch
发表于 2021-12-11 15:51:39 | 显示全部楼层 |阅读模式
Ok, I'm feeling dumb. Does anyone know how to remove the porcelain knob from old Arrow HI-MED-LOW-OFF switch? I can pull up on it and it feels spring loaded but will not come off. I've pulled, poked, and wiggled. Any ideas?Thanks!
Reply:I got it! You pull up over the key and unscrew it.
Reply:I was going to say, "If you can't figure it out..."The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Glad we could help
Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-19 11:54 , Processed in 0.098034 second(s), 18 queries .
