Shootr's 2 x 48 Belt Grinder Build
发表于 2021-12-11 15:51:39 | 显示全部楼层 |阅读模式
Now that I have the shaft of the buffer prepped, I'm starting to think about the design for the grinder.  Since it's been done 1000 times by others, there are plenty of pics and guides to work from.  This is the first iteration/idea using some luan.There will be a base of 3/8" plate that the buffer will bolt to.  A vertical plate of 1/4" will be welded and gusseted to the base and bolted to the buffer face.
I'll be using a 5" drive pulley, a 3" guide/tension pulley, and 2 - 2" idler pulleys.  I'll also make my own "D" plate/platen.   Got some heavy wall telescoping tubing to help with that.
The pulleys will be here next week, probably work on the platen tomorrow.Should be a hoot!
Last edited by Shootr; 8 Hours Ago at 07:19 PM.Yeswelder MIG-205DS(3) Angle Grinders at the ReadyJust a hobbyist trying to improve
Reply:What do mean by "plug weld mounting bolts?" Hopefully you mean welding the backside of the bolts (with head cut off) flush in the holes. You need to get some better steel that isn't a rusted mess.
Reply:Are you planning on any stiffners on the upright plate? 1/4" isn't much for that. On the 2"x 48" upright I used 3/8" plate and if I was to do it over I would have used 1/2". I used a face mount motor but you will get deflection with that 1/4" plate even with the  flat base mount.
Reply:Interesting build, cant wait to see it completed.Lincoln 330 MPXModified TombstoneLincoln LN-25X-TVTMagnum PRO 250LX GT Spool Gun¼ Ton of Torches OFC-A / OFG-ASMAW FCAW GMAW Air Carbon Arc Gouging#Freebird Welds
Originally Posted by Shootr
I had faith the 1/4" would suffice. I would be able to add a couple of vertical L channels where the red lines are, and the square platen holder tube should be good for the horizontal.
GMT+8, 2025-12-19 13:18 , Processed in 0.087763 second(s), 18 queries .
