Welding ¼” metal with smaller than optimal welder
发表于 2021-12-11 15:51:38 | 显示全部楼层 |阅读模式
I’m in a make do situation, have a 230iMig but am off grid & don’t have big enough clean power generator to run it at moment.I do have a Lincoln SP130T 230 amp, 75/25 gas, Lincoln.035 solid wire.Not optimal machine for what I need to do, but hopefully workable.I need to weld set of rear spring & shackle hangers onto the chassis rails.I need to weld the ¾” plates to the ⅛” chassis rails and then weld three ¼” pieces between the bigger side plates and ¼” hanger to the mount. Will bevel the edges where can on the ¼” pieces.The pics are of first chassis I built.Thinking of two options, run one or two passes with smaller welder & then finish welding with 230 iMIG or make multiple passes with smaller welder.One thing want to do is seal all edges & seams so moisture can’t get between pieces. Otherwise would just tack everything good & finish with 230iMIG.Need to mount the spring & shackle hangers so can work on tub.Cheers, AllenSorry about the huge pic size!
Reply:What is a "make do situation"?  Cannot get another machine? Cannot run flux core?  Cannot buy a stick welder? Is mig/gas what was provided?That 130 is 230v, Correct? The 230 is an option?Flux core would be my first choice if i had to use the 130 machine.Last edited by tapwelder; 1 Hour Ago at 02:16 AM.
Reply:I've been in lots of "make do " situations. Building a vehicles' suspension that will hold the fate of people's lives isn't one of them.The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:I would pre-heat the parts to 300 degrees F and try the welder you have,,HF sells a cheap propane weed burner that will heat those parts in no time,, DO NOT be bashful with the propane,, the heat REALLY helps,,
GMT+8, 2025-12-19 11:54 , Processed in 0.067788 second(s), 18 queries .
