Do you EVER Repurpose, To Get The Job Done??
发表于 2021-12-9 15:51:15 | 显示全部楼层 |阅读模式
I saw this idea, and thought it was great, and had to share,,
That clamp would sure be faster than turning a C-Clamp,,Do you have any ideas that repurpose tools that others could use??
Reply:Piece of flat bar across the piston and it doesn't take so many turns.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:I never replace brakes...........I've always driven like an old man
Actually............two sets of front pads, and the first set of rear shoes last year...............IN 275,000 MILES.  Rear drums were still good, but the front discs needed replacing on the last go 'round.  It pays to drive like Gramps
  I mean REALLY pays.  $650/year for liability insurance on TWO trucks, with max non commercial coverage.  To be fair, it's a bundle with the farm insurance.  But it helps to not have had a moving violation since I was around 18 or so.  Overweights, and other stuff, don't count as moving violations....at least they didn't used to.
Reply:I repurpose constantly. When we were laying some cable recently I needed a caddy to spool the wire out, so my barrel dolly got repurposed temporarily with some SS hose clamps.
Got the job done and now it's returned to it's normal life as a barrel dolly for wheeling around 45 gal (205 l ) barrels of oil.
The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Who doesn't?  How am I going to unroll this heavy (few hundred lb) spool of wire that feeds power from house to shop? Here's how:
-DaveXMT304 with: 22A Feeder, or HF251 Hi Freq DC TIG air cooled
Reply:You can just lift that up on my barrel dolly if you want to borrow it...The harder you fall, the higher you bounce...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:I don't have undergound feed
  But I gots 5 extension cords!!!!!!
GMT+8, 2025-12-19 11:54 , Processed in 0.100874 second(s), 18 queries .
