Need a wiring diagram for SAE generators
发表于 2021-12-8 15:51:21 | 显示全部楼层 |阅读模式
Hello everyone,I have successfully re-insulated the wiring in my SAE-600. But I'm not sure if it was hooked up right when I bought it plus there's always the chance that I got something wrong. I want to check the current wiring against a wiring diagram for the generator.Does anybody have a detailed wiring diagram for an SAE-600? The only ones I've found have been heavy on details for engine wiring and pretty vague about the generator internals
Reply:If you can find the serial number and code numbers, call Lincoln they might still be able to send you something. If the serial number/ code plate is gone. check the barrel of the generator is might be stamped on it some where.
GMT+8, 2025-12-19 11:57 , Processed in 0.070832 second(s), 18 queries .
