*NEW* Weldpro MIG 220D / Amico Cut 50 Plasma Cutter / Welding Accessories For Sale
发表于 2021-12-8 15:51:20 | 显示全部楼层 |阅读模式
Near the RI/CT border. Complete set-up for someone in need. Contact info in link. Merry Christmas, TheW.$650 for the welder kit$200 for the plasma cutter kit$120 for the spool gun$1200 for everythinghttps://providence.craigslist.org/tl...417937321.htmlThe Weldpro 200 Amp Inverter 3-in-1 multi-process dual-voltage welder MIG (DC)/ Flux Core/TIG(DC)/Stick(DC) that automatically adjusts and compensates both voltage and wire speed together while at the same time allowing the user to fine-tune voltage independently. Light, compact unit (30 lbs). This unit is capable of performing MIG, Lift TIG and Stick welding equally well at a maximum 200 amp output. Dual Digital display easily sets amperage and wire speed. 2T/4T modes, spool gun capability, and advanced DC lift TIG features. Welder handles aluminum when used with the optional spool gun in the MIG mode. Lift TIG welding even allows for brazing of dissimilar metals using The TIG braising technique. Package includes 1. 10ft MIG torch ERGOPLUS15; 2. TIG torch: 13 ft. WP-17V; 3. Electrode holder: 5AWGx10 ft. 200A cable 35-50 quick connector; 4. Earth clamp: 5AWGx10 ft. 300A cable35-50 quick connector; 5. Gas hose: 55; 6.Power adapter.Also available:Amico Cut 50 Plasma cutter w/ SG55 gun and 10' 300A work clamp & cable - $200Weldpro SB8 spool gun - $12020" Metal toolbox - $45Antra auto-darkening helmet - $304' x 6' Fiberglass welding blanket - $10Blue Demon welding rod 1/8"/3.2mm 1# - $10Hobart stick electrodes 5/32" 6013 - $10Carbon steel flux-cored wire .035 - $15Hobart Aluminum MIG wire .030" - $30Hobart welding pliers - $10Hobart chipping hammer w/ brush - $10Leather welding apron - $20Welding goggles - $10CNA welding kit 5052 aluminum cube 2" x 2" x 1/8" - $10CNA welding kit steel cube 2" x 2" x 1/8" - $10CNA welding kit steel cube 2" x 2" x 3/16" - $1024 piece plasma consumables kit - $15
GMT+8, 2025-12-19 11:55 , Processed in 0.070200 second(s), 18 queries .
