Cyclomatic wire feeder to smt 400
发表于 2021-12-5 15:51:17 | 显示全部楼层 |阅读模式
I got a smt 400 and a cyclomatic power drive too the wire feeder unit I don't believe it has the original cable that goes to the pinout it's got a seven wire system that comes down to alligator clips was told that it was used to hook to a Lincoln idle arc does anybody have a wiring diagram or know how to wire a new wire inside the cyclomatic power drive I have the smt 400 owners manual so I know where it needs to get connected on the power unit but where it needs to go in the wire feeder I have no idea help would be much appreciated.Cheers Justin
Reply:Post a picture of the power drive. see if it is  Type 1 or type 2Then I can check the archives.
GMT+8, 2025-12-19 11:52 , Processed in 0.087428 second(s), 18 queries .
