Miller Bobcat 250 no generator power or weld
发表于 2021-11-29 15:51:18 | 显示全部楼层 |阅读模式
Started up my welder and rolled out the leads, come to find no spark. I the. Checked all connections and tried the generator and no power. Removed from truck and in shop now, all metal side off all wiring exposed. I read some threads on the web to check the 2 fuses and the two full bridge rectifiers? I replace both of each and a new capacitor and still no power? All components look great and the armature checked out 3.4 ohms . Brushes were good and the rings look clean? Any help would be appreciated!
Reply:Serial # LE440485 Stock #9072112004 year
Reply:Hope this helps!AndyESAB 350 MPI ESAB 330I CVCCLincoln Idealarc 250Eastwood TIG 200Hobart Ironman 230Hobart Plasma CutterLincoln 110v MIGCH 110v MIGMK Industries Cobramatic with Prince XLMiller XR Wire Feeder
Reply:I've had a similar problem with my old BB400 D,  I called Millers customer service, Engine Drive department.   They walked me thru it over the phone, we did some checking with Multi meter.  Call them they'll put you in the right direction.It seemed like a good idea at the time!
GMT+8, 2025-12-19 11:52 , Processed in 0.092855 second(s), 18 queries .
