Millermatic 210 contactor issues
发表于 2021-11-25 15:51:28 | 显示全部楼层 |阅读模式
Hey guys,I have a 210. purchased it new years ago. Recently a few issues have arouse. Welding very bad, no penetration, very sporadic wire burn, lots of splatter.   Ground clamp getting really hot. (replaced clamp and wire, problem cone) still not welding like it shouldReplaced the contactor with new one points were toasted. Problem went away for a little while. Looked at contactor today and it looks bad already. Maybe 5 Lb. of wire through it. See pictures below, I took it apart and these are the point only. If this is bad what can be causing the contactor to go bad so fast.Any ideas would be greatly appreciated!!
GMT+8, 2025-12-19 11:55 , Processed in 0.080209 second(s), 18 queries .
