mobile welding business
发表于 2021-11-24 15:51:32 | 显示全部楼层 |阅读模式
I just started my mobile welding business and wanted to know how much to charge for a 9’x 40’ double slide gate with corrugated metal instead of vertical bars. He is making me work with used metal that has vertical bars 6” apart on a 3” square tubing frame and I’m going to install it and even have to do the concrete work because there’s asphalt where the rail is going to be so i have to cut it out and put the concrete in.
GMT+8, 2025-12-19 08:18 , Processed in 0.145138 second(s), 18 queries .
