Ridgid 450 chain vise repair
发表于 2021-11-22 15:51:28 | 显示全部楼层 |阅读模式
Would anyone know what metal the “ table”is made of?   I’m needing to make a repair and have trouble making anything stick.    The handle broke years ago and Dad just used a pipe wrench to tighten the vise.    In doing so, he washed out where the retaining pin drives in to capture the handle.   I placed a brass rod in the retaking pin hole and attempted to Mig around the brass pin to build up the hole.   The weld just flakes off the base material.   Any different ideas would be helpful and appreciated.
Sent from my iPhone using Tapatalk
Miller BobcatHarris cutting outfitMiller spectrum 625 plasmaVariety of shopmade tools
Reply:To determine if it's cast iron, drill a small hole in a non critical place.  Just enough to make some stuff pulled out by the bit.  Check out the video I did on turning the brush hog hub.  If the "chips" look like that, it's cast iron, and will need brazing to fix it.  Drilling is easier, and more accurate, than a spark test from grinding.  Small granular chips............cast iron.  Longish shiny ribbons.........steel.
Reply:Thanks Sam Sent from my iPhone using TapatalkMiller BobcatHarris cutting outfitMiller spectrum 625 plasmaVariety of shopmade tools
Reply:I've used the Harris Low Fuming Bronze 15 rods with success.  I don't do that much brazing, so others might have better suggestions.https://www.harrisproductsgroup.com/...e-15-BARE.aspxGet a can of flux, and you're in business.
Reply:Irish Fixit used to be a member.  He passed a few years back.  This is part of his legacy.  Great fella to talk to, and get advice from.
Reply:This guy does a lot of excellent brazing work, and some excellent machine work.
GMT+8, 2025-12-19 13:46 , Processed in 0.232092 second(s), 18 queries .
