Clarke parts
发表于 2021-11-22 15:51:27 | 显示全部楼层 |阅读模式
I got a Clarke 130EN MIG, given to me. I just want to see if it actually works. It came with a few accessories such as a self dimming helmet, brushes, a circle cutting tool, hammer and two spools of wire. One spool says for gas, the other, label missing. It also is missing the nozzle.Can anyone tell me if the Clarke will accept nozzles or tips from a Lincoln or any of the other brands? Also, I want to put in a dedicated outlet for this welder, would a 20 Amp be enough? Thanks for any help.
Reply:u need to look at primary input on back of welder for how many amps it wants.        i wouldnt know, i guess measure threads, or could take gun to welding store and try threading some in, or see if lincoln/another diffuser will thread into gun.   if so u might be able to make something work like ur hoping
GMT+8, 2025-12-19 15:20 , Processed in 0.126700 second(s), 19 queries .
