Lincwelder 225 with onan engine
发表于 2021-11-19 15:51:31 | 显示全部楼层 |阅读模式
Hey guys new here I have a late 70s Lincwelder 225 with a onan motor generator. I’m striking out hard with the solenoid and wiring it sense it doesn’t have a starter and uses two twelve volt batteries instead. It’s a new solenoid . I put all new spark plugs two new batteries cleaned up the electrical connections and still nothing when I hit the ignition button.
Reply:Sounds like it's about same as my old Hobart which uses 24v in windings in the generator to crank it. It doesn't have a solenoid instead uses a momentary pushbutton switch to energize the windings. Does your new solenoid energize when you push the button? If it does then there's a problem between it and the windings.  My advice is to try to PM "duaneb55" here. He is our resident portable welder expert.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
GMT+8, 2025-12-19 13:46 , Processed in 0.099620 second(s), 18 queries .
