Best DC Tig Helmet for a newbie?
发表于 2021-11-18 15:51:37 | 显示全部楼层 |阅读模式
Recently got into DC Tig as I want to do exhaust pipes and bike frames later on. I have the basic Lincoln flux core helmet (not sure how specific I can be), basically it’s like $70 bucks and it’s auto darkening. I have noticed that sometimes while I get a very consistent, narrow stable arc (so hopefully for the entirety of the weld
) that my helmet will (un-darken?) if that’s the word. Is there any solution to this or will I need a second helmet? If so, what’s a good beginner one that won’t break the bank (maybe keep it under $150). Thanks.
Century FC-90Primeweld TIG 200D
Reply:which model Lincoln helmet?there isn't a Tig dedicated helmet per se but the ones with more $$$ next to their name usually have have better sensors and have a  larger shade range settingEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:IMHO....  And especially for TIG work, your helmet is not a "budget item"
There actually is a stark difference in what you see with an expensive helmet (kinda like SD and HiDef) and nowhere is this more beneficial than in watching a Tig puddle for the earliest signs of things going, just slightly, array. I learned to Tig with a 10shade piece of glass, got an early AD, but with the first purchase of an Optrel (used and I think @$150) I was Amazed at the subtilties I was missing with anything else. I'd never go back!
Reply:This is the helmet I have at the moment.https://www.homedepot.com/p/Lincoln-...57-1/202715826Century FC-90Primeweld TIG 200D
Reply:Looks like the one I have it works great.Dave
GMT+8, 2025-12-19 13:50 , Processed in 0.090930 second(s), 18 queries .
