Generator for stick welding
发表于 2021-11-17 15:51:34 | 显示全部楼层 |阅读模式
A buddy of mine needs washers welded on some feet of shooting barricades and my question is can I run my ESAb 180i at around 80 to 110 amps off of a 4500 staring watt 3600 running watt generator just for some small tack type of welds without blowing the fuses and having a rough time? It would be ran on the 110 plug adapter.
Reply:Should be ok. I would use 3/32" ,6011. Should be able to run those at 60 amps.
Reply:Good luck A wire type would workDave
GMT+8, 2025-12-19 13:50 , Processed in 0.070181 second(s), 18 queries .
