Cutting question
发表于 2021-11-17 15:51:34 | 显示全部楼层 |阅读模式
I am switching from acetylene to propane.   Besides a new proper propane tip what else do I need to replace to my old Victor torch system?   Thanks in advance.
Reply:https://weldingweb.com/vbb/threads/7...utting+propaneEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:That is only thing you All the equipment is same but the tip.Dave
IBesides a new proper propane tip what else do I need to replace to m?   Thanks in advance.
Reply:If you look at dedicated propane setups they are different from acetylene kits. Doesn't mean you can't use what you have with the correct tips I recon. The regulator is a 50 psi for Propane and a 15 psi for acetylene.The hoses are T rated for the propane gas so they don't break down over time from the incompatible gas.And of course the tips as mentioned. Look at regulator part numbers. The middle number is max pressure. Acetylene 15 psi Propane 50 psi.Hose types and sizes. 3/16 acetylene 1/4" propane. Propane is T rated for propane gas.Propane,https://www.millerwelds.com/equipmen...it-mba-30510lpAcetylene,https://www.millerwelds.com/equipmen...-300-mba-30300
Originally Posted by 123weld
i think theres a diference in hose.    i cant remeber for sure, or how much it matters, but think there  is a differnce  hose for propane
Reply:I took the acetylene equipment and put on propane tank and changed the tip.Dave
Reply:When I started cutting with propane I never even knew that there was a different tip and hose for itI'm still using the wrong hose
GMT+8, 2025-12-19 07:02 , Processed in 0.099618 second(s), 18 queries .
