Miller XR control wire feeder compatibility with other miller guns?
发表于 2021-11-14 15:51:47 | 显示全部楼层 |阅读模式
Hey guys, I'm new to owning Miller stuff, so I'm trying to research as much as I can before blindly spending money on more things. I have a Miller XR wire feeder, originally set up to feed aluminum wire. It did NOT have the expensive pull gun included. What I want to do is set it up with a standard MIG gun for regular steel wire. I have an ESAB CCCV power source for it.Does anyone here own one and could you check to see if it accepts "normal" Miller guns? I'm pretty sure that it's a standard Miller hookup, but since I don't have a gun I can't check. Also don't want to spend money on a gun only to find out it won't fit/work.If it does fit, could you include the model number of your gun? I appreciate your time and interest in helping out a noob!Thanks in advance!
GMT+8, 2025-12-19 13:52 , Processed in 0.097224 second(s), 18 queries .
