TIG setup for Miller Syncrowave 210
发表于 2021-11-13 15:51:36 | 显示全部楼层 |阅读模式
Hello all, the company has a 210 but only has a stick set up. Where is the best deal on a complete setup or should I just piece it out? Right now aircooled would be fine, this is for intermittent fabrication and maintenance welding. I have looked around some but there are so many options it gets confusing to me what would be the best way to go. Thanks, Jim
Reply:HTP America is going to be your best bet. Foot pedal  https://usaweld.com/products/25-foot...30a59d28&_ss=rTIG Torch  https://usaweld.com/collections/mill..._flow_thru_gasFlow Meter  https://usaweld.com/products/flowmet...88101804&_ss=rMiller Multimatic 255
Reply:HTP is a good company to deal with, if you buy from them, let them know what you'll be welding and they will make sure youget the right torch consumablesRichardWest coast of Florida
GMT+8, 2025-12-19 13:50 , Processed in 0.098411 second(s), 18 queries .
