Nov2021 Hi WeldingWeb, longtime no post. Here is a recent video : Airco 5/32" E6013
发表于 2021-11-13 15:51:36 | 显示全部楼层 |阅读模式
I have a recently scored a rare box of my favorite all time E6013 rod[I used it by the ton at Warner & Swasey  Co., building machine-pan bases.   It is vintage Airco #613 circa 1974 Made in USA 5/32" E6013 [NO LONGER AVAILABLE]   Best all position rod, beats Lincoln fleetweld 37 IMHO [less slag operates like an E7018]  [Hobart 447A E6013 is a very close available today rod to it]Cheershttps://www.youtube.com/c/AWDJRforYouTubeCentury AC/DC 250 Amp & Midstates 300 Amp Industrial AC stick welders, Century Flux core 80 amp. wire feed welder  Harris Oxy-Acet. cutting & welding outfit:SEE MY INFORMATIVE VIDEOS AT http://www.youtube.com/user/alpho52
Reply:No offense but that was a boring video. No arc shots, no close up of the weld bead. What's the point?Miller Multimatic 255
Reply:Thank you, JUST AN ACTION cameo video...point well taken!
Reply:Thanks, just a channel cameo video to get folks to check my channel No point in particular...Century AC/DC 250 Amp & Midstates 300 Amp Industrial AC stick welders, Century Flux core 80 amp. wire feed welder  Harris Oxy-Acet. cutting & welding outfit:SEE MY INFORMATIVE VIDEOS AT http://www.youtube.com/user/alpho52
GMT+8, 2025-12-19 07:02 , Processed in 0.108781 second(s), 18 queries .
