Sa 250
发表于 2021-11-13 15:51:35 | 显示全部楼层 |阅读模式
Hello.  I recently have bought a Lincoln sa 250. Code 9022-h.   The machine will not go to high idle when strike a arc.   It will go to high idle when you use the 120volt outlet and with the toggle switch.   Was wonder if anyone has had this problem before.    Thank you
Reply:The only problem with 120 DC it is DCYou have buy tools that will run on DC.Dave
Reply:Last time I used one was in Port Everglades in 1990 or so. Was diesel.www.urkafarms.com
Reply:That good Most welders at time only had dc and it was a pain.Dave
Originally Posted by 12V71
SA 250s had AC auxiliary power.
GMT+8, 2025-12-19 13:51 , Processed in 0.093187 second(s), 18 queries .
