Good 4.5-5" air grinder light and powerful?
发表于 2021-11-13 15:51:35 | 显示全部楼层 |阅读模式
Looking to get a new one. I like the small aircat we got at work. Says its 1 hp and it's very light and nimble. Looking to see other options. We use the ingersoll rand 3345 also. There nice but I'd like more power. we got some mac ones too that have good power but heavy and exhaust blows with uber high pressure right onto you're hand. Insulated is a big plus since it's getting colder. The boss got a new cp that he says was 200$ and it seems smooth and strong
here's that aircat
Reply:Aircat builds some really good impact wrenches, I would think their grinder would be good too.
Reply:I have the extended reach Aircat and use it every day.
“Apparently” they excel at removing tack welds on screwed up fabrication projects!
Sent from my iPad using Tapatalk
Reply:Nice, back when it was shiney, I  wanna get a 45 degree angle die grinder for cutting tacks and welds in tricky spots. I see proto sells one for little over100$  . I like the power of s and p die grinders. But a guy at work says it burns the bearings fast. In 1 year for him.
Reply:Just curious - why do you guys all prefer air over electric?Over here in the UK, pretty much everyone uses 110v grinders, 800w to 2200 watts for a 4.5-5". You can do a LOT of damage with 2.2kw going through a 4.5" disc
I see a few guys in australia prefer air over electric as well.
Murphy's Golden Rule: Whoever has the gold, makes the rules.
Reply:Aircat has a ~2.5 HP 5" grinder for around $350 on Amazon, but you need like 60+ CFM to run it.  I have a couple of CP 4" air grinders, about 0.8HP or so, and they are nice, but the exhaust blows out the front, which is not good if you plan to weld in that area.  I got them for $80 brand new, so they were a steal.
Reply:Oscar has a nice grinder collection there, but pay attention when he says they use a lot of air. If you've got 10 guys working in the shop and everyone is at the air, a big HP grinder might be the tipping bucket for your air supply.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:This lightweight Nitto  Kohki has tons of power. Exhausts away from the operator.
Sent from my iPhone using Tapatalk
Reply:Lot of air, equipment and power to run a little disk. That is the main reason to use electric, its why I use it. I have air but limit it to use on more specialty grinders instead of the air comp firing every time I want a little zing.  Dont need to run 10 hp to do the work of 3/4 or less.
Reply:The CP are a deal for sure. I mainly use 1/4 hard wheel for everything humanly possible and then I like the air on wire wheel and cut off. Some pricing has got more competitive, at one time those cost 200 maybe?   Those 3 are my staples in air grind.  The right angle is generic, can be found under a couple brands, I use it for wire and cut off and is one of the most durable tools I ever use.  I have 3 of my own, have used others and am NOT a hobby type.  Had a guy run one steady for 3 months, have never so much as had to tighten a screw on one.
www.urkafarms.com
Reply:I should get a new long reach but,,, I really dont find myself backed in as much as I used to.   As for the wheels,,, I been using HF and the 10 pack from the farm store were a dollar a piece, I think maybe 150 now.  Once in a while I run a couple wheels off on a job but they go a long way and only time I can really tell some difference is if I am really leaning on them and even then its not night and day, I have ran them side by side,,,, to me simply not worth the worryu and the effort, so I put one or 2 more on in a month,,,,    I get anxiety attack if I see the stack going down too far and makes it almost painless to replenish.    Now,,, I say this with respect,,, nothing wrong with top end and quality tools. Nothing at all but along the way we found some gems we lean on and in the end like as good or better. I am not a collector, wouldnt have it unless I needed it and really like taking the pain out of getting what I need when I need it with the modern economy tool.  My go to drill is now a 50$ one from Walmart as is the grinder.  There are 2 cheaper grinding wheels, one better than the other. Replaced my worn drivers with HF, 30 new ones for 50$ and like as good or better than the Klein.    Bought a roll of solid wire from Menards the other day and a spool of alum from Home Depot.  30 yrs ago would have bought the best from the jobbers but all that cost now and is so time consuming and I aint blowin the guy at the house just so he might gimme some deal.www.urkafarms.com
Reply:I had 2 or 3 CP chisels we ruined,,, after that got one from NAPA in a pinch and it still works, go figure? Some of that stuff simply cost too much to fix, aint putting 50 or 80 in to a worn out ratchet can be replaced for 100.www.urkafarms.com
Reply:I went thru a bucket full of "better" brand grinders and now in the last 15 yrs or so have used 4 and maybe on 5 now of the BD.  bought 2 on sale for 20 and other 3 full price at 30 and recently opened my last new one when the spindle lock failed on one, I should salvage from another, I fixed a switch on one ran another 3 years every day, not replace but fix,,, and never have to replace a cord.  Cost me 100 bucks for grinders for 15 years, brand cost me that every year.www.urkafarms.com
Reply:For me its about what it takes to do the work, you can throw as much as you want at it though.www.urkafarms.com
Reply:A guy that uses to work here has this 7" grinder. Thing made a ton of torque and power
Closest I could find was this one for $450....https://www.amazon.ca/Nitto-Kohki-ML.../dp/B00NV7HTD0
Reply:The 7 is a sander and it is one of my go to tools, 36 grit.www.urkafarms.com
Reply:80 cfm is close to 20 hp from single phase.www.urkafarms.com
Originally Posted by Josey
I would have to agree with  Sberry    I wouldn't  want to run a large compressor  for  every small  grinding job while I'm welding  For the same reason  I would  never want to run an air  needle scaler  while I'm  welding
GMT+8, 2025-12-19 13:47 , Processed in 0.071103 second(s), 18 queries .
