Dedicated tungsten Grinder
发表于 2021-11-13 15:51:35 | 显示全部楼层 |阅读模式
I need a proper tungsten grinder that allows me to use a few different angles.Is this 3mirrors ALUMINUM Tungsten Electrode Sharpener for 150 bucks any good? Amazon ratings are at 4.4 Any other suggestions?https://www.amazon.com/3mirrors-ALUM...8M3984L8/?th=1
Reply:sounds expensive for just having an attachment on a cheap dremel. if you already have a dremel then maybe you can find just the attachment? cant comment on how well they work tho.
GMT+8, 2025-12-19 13:53 , Processed in 0.080469 second(s), 18 queries .
