AEAD-200LE Legend help
发表于 2021-11-10 15:51:27 | 显示全部楼层 |阅读模式
Anyone who can take a bunch of pics of the 005563 selector switch from inside, I’d be very grateful. The more the better, as many angles as you can get me, especially the rotor spring and the contacts. Got myself into a bind. Changed the faceplate on the ol gal, and snapped the selector knob clean off (best $100 bucks I ever spent on a thimble of aluminum, mind you). Here’s  my idiot moment of the day: I tried to not dismantle it. I drilled out the rivets, got the old 005561 shaft out (g’head: ask me why that number is memorized
), slipped the new shaft in place (without riveting it,) and put it all back together with the new knob. Guess what? Can’t slip the rivet gun in that spot no way, no how. Decided to quick quick break it down, and what’s you’re destiny in this situation when you’re being a careless idiot? Things fall all over the floor. I have no idea in which configuration this goes. - how do the contacts reassemble?- does it matter what side the spring goes on?- why did I find a small 3/8 brass bushing on the floor with the rest of the parts (dear god help me)?Any help would greatly be appreciated.
GMT+8, 2025-12-19 13:50 , Processed in 0.091289 second(s), 18 queries .
