Victor oxy reg rebuild
发表于 2021-11-9 15:51:32 | 显示全部楼层 |阅读模式
Hello all,      Went down to our local welding supply store, exchanged the oxy acetylene tanks with hopes of doing some horseshoe art and?       Oxy regulator had other ideas! Phhhhst! HP out the blowby! Yeah the hiatus from the rig was often in a HOT shop. Was thinking buying new.... Fixed income changed that idea!      I did a bit of searching and rebuilding looks easy for a decent mechanic. Problem? This Victor is a model SR-95. I do not find this model number on any overhaul kits.      Are any kits interchangeable with this model? Thank you in advance, enjoy your day☺☺
GMT+8, 2025-12-19 07:05 , Processed in 0.102573 second(s), 18 queries .
