Keep my 225 AC buzzbox?
发表于 2021-11-4 15:51:32 | 显示全部楼层 |阅读模式
I had a lincoln weld and power. it did DC /  AC. So I never used this 225 buzzbox at all. I now have a Ranger DC only, I dont ever have use for AC. Should i sell the buzzbox or install a rectifier bridge in it so i can do DC /  AC and keep it?its just it takes up space in the shop.
Reply:I don't see the point in keeping it unless it's your only backup welder.I assume you have more than just the Ranger to weld with, though? Surely you have a few more shop machines?Even as a mobile welder you might pick up better business by having more modern machines... a DC inverter or two would probably be a good idea for when you can run off mains...Even a little lunchbox welder would be more practical than an AC225. Something you can carry in one hand and run an 1/8" rod on all day long.If someone turned up to our site with an 225 I'd wonder what their business plan was.Last edited by Munkul; 1 Day Ago at 08:00 AM.Murphy's Golden Rule: Whoever has the gold, makes the rules.
Reply:Sell it and buy a dc buzzer if you need one but the idea of a lunchbox is even better.  Mine has near put my engine drive out of biz, so much simple work now done 120V, used to need engine every time we got a little way from the shop.www.urkafarms.com
Reply:Yeah I actually have too many welders that's why i am thinking of selling that one. I just bought it from a guy when i was also buying a drill press.I do most everything with the engine drive when away from the shop.What do you think the 225 ac is worth? its in nearly brand new condition.
Reply:In my area they seem to sell for $200 to $400 depending on condition, and accessories. You might want to consider throwing in an old helmet and maybe some old 6013 in to seal the deal, selling to a beginner. There are some people that want these for limited use because they're  very reliable (is just a transformer and a switch). AC/DC go for $400-$500 it seems, lots to be found on craigslist, marketplace. There are lots of "more portable" welders available now, better off letting someone else have that one, and get a small multipurpose welder. Good LuckPS where are you located  ?Airco 250 ac/dc Heliwelder Square waveMiller Synchrowave 180 sdMiller Econo Twin HFLincoln 210 MPDayton 225 ac/dcVictor torchesSnap-On YA-212Lotos Cut60D
Reply:What do you think the 225 ac is worth? its in nearly brand new condition.
Reply:I always use AC for tacking,, and other things that require multiple short welds.  It's a PITA to restrike DC 7018.  The AC version of the rod lights up easily.Also like AC when arc blow becomes unmanageable.  I bought my engine drive because it was AC capable.  I really like having the AC function on the 250GXT.I guess it just depends on how you're used to welding, and what consumables you tend to use.
Reply:I listed it on CL in my area but no takers for $200, that's what im asking cause that's what i paid.Im in Northern VT
Reply:No takers in less than a day? Give it a week or two! lolMurphy's Golden Rule: Whoever has the gold, makes the rules.
Reply:People actually part with old welders??  Does this require some sort of legal documentation? You know... like a divorce?250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
GMT+8, 2025-12-19 13:48 , Processed in 0.094594 second(s), 18 queries .
