Help! Miller legend
发表于 2021-11-2 15:51:29 | 显示全部楼层 |阅读模式
I got an miller legend welder with an Onan motor on it. But I'm not getting any fire to it. Put a new coil on it. Might be the points but I’m not for sureAny ideas of what could it be?
Reply:did you check to make sure that the coil is being energized when you turn on the power?
Reply:Have you looked at the points? The set in my machine had a lot of corrosion. Replaced the points and condenser at the same time. Check the plugs and wiresAirco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power
) Hobart MIG
GMT+8, 2025-12-19 07:02 , Processed in 0.143218 second(s), 18 queries .
