Skeg Repair
发表于 2021-10-30 15:52:12 | 显示全部楼层 |阅读模式
My friend and customer Steve has owned this 27’ boat for 25 years.  Counting the boat that he had before this one, he has owned power boats for 35 years. Steve’s strategy is to leave the boat in storage and trailer it to the lake every time that he uses it. For the first time in 35 years, he forgot to raise the lower unit of the inboard/outboard drive when he pulled the boat out of water.  As a result, he wore about ¾” from the bottom of the skeg. My task was to replace the worn off piece of the skeg. Steve felt that the bottom of the skeg helps to protect the two counter rotating stainless-steel propellers, which cost ~ $2,500. If the skeg hits something on the bottom it will likely cause the lower unit of the inboard/outboard drive to rise and avoid damaging the propellers. (At least that is the theory.)1. Steve’s 27' boat-1
2. Steve's 27' boat-2
3. Worn down skeg
I know that it is low tech, but I just used a cardstock pattern to define the shape of the replacement piece for the skeg.4. Cardstock pattern
Ryan Jones from the Miller Welds forum queued me in regarding the availability of replacement skegs.  It turns out the skegs are airfoil in shape with the center being about twice as thick and the leading and trailing ends.  In our case the center was .220” and the ends were .100”.  I compromised by using 3/16” stock. If you want to be geometrically pure, you would have to cut the bottom off of the replacement skeg tip. Another option is to use 1/4” stock and do a lot of grinding if you want to blend it to the existing skeg.5. Replacement skeg tip
Smith Oxyacetylene TorchMiller Dynasty 200DXLincoln SP-250 MIG WelderClausing/Coldchester 15" Lathe16" DuAll Saw15" Drill Press7" x 9" Swivel Head Horizontal Band Saw20 Ton Arbor Press BridgeportLincoln LE  31 MP & Lincoln 210 MP
Reply:6. Cutting replacement piece
I like to use a copper backup plate to protect the back of the weld from oxidation during welding.7. Copper backup plate
I used garbage cans and a small shade to protect me from wind. The part that I was welding was far enough from the gear box that I didn’t worry about burning up the grease. I also took my time welding it, so it would cool off between welds.8. Me TIG welding skeg
9. Close up of me welding
10. Skeg welded
Reply:When you grind aluminum make sure that you use a wheel designed for Aluminum, like the one shown below, otherwise the wheel will load up. 11. Aluminum grinding wheel
I like to back gouge to ensure that I remove all of the oxidation from the back of the weld.12. Back gouging skeg
In the evening here in Michigan it is currently in the low 50’s, so I used my shop lights to help the paint to dry.13. Using 2x 500-watt lights to dry paint
14. All done and painted-1
15. All done and painted-2
-Don
Reply:Always look forward to your posts - very informative and always impressive.Yeswelder MIG-205DS(3) Angle Grinders at the ReadyJust a hobbyist trying to improve
GMT+8, 2025-12-19 13:47 , Processed in 0.064911 second(s), 18 queries .
