查看: 13|回复: 0
3500# Trailer Axle Modification
发表于 2021-10-30 15:52:11 | 显示全部楼层 |阅读模式
Just wondering has anyone ever removed the axle tube mounts from the top of the axle and re-welded them on the bottom to switch from over slung to under slung? Or would you just weld on a new set and leave the other ones?Thanks.Millermatic 211Lincoln Precision TIG 225Century 250 MIGLincoln 225 AC Box (sold)I support my local welding store (Amazon, McMasterCarr, Cyberweld, EBay).
Reply:I have cut them off an repositioned them and after I was finished I decided I would never do that again!
The new ones are too cheap!
Reply:I added new ones and left the old mounts when I wanted to lower a motorcycle trailer.
GMT+8, 2025-12-19 13:56 , Processed in 0.092135 second(s), 18 queries .
