Lincoln SA 250 No power
发表于 2021-10-25 15:51:24 | 显示全部楼层 |阅读模式
So I’ve got an old SA 250 Perkins. She sat sat for a few years, got it fired up, engine runs but no power weld or accessory. Also noticed when I reconnected the battery, that the hour meter continuously runs even with the machine off. Tried flashing the field coils per the manual. The main fuse had the terminal corroded off, fixed that…. Still no power. Any recommendations?
GMT+8, 2025-12-19 13:57 , Processed in 0.145993 second(s), 18 queries .
