I know this is probably obvious
发表于 2021-10-25 15:51:23 | 显示全部楼层 |阅读模式
But can you cut an exhaust pipe with an Oxygen MAPP/Propane Cutting Torch? Or is that not strong enough?
Reply:You can definitely use it to cut exhaust pipe however there are better methods.  Exhaust pipe is so thin you're probably better off using a sawzall, cut wheel, ect.,  You will be left with a much better cut and less work In terms of clean up.
GMT+8, 2025-12-19 14:49 , Processed in 0.091532 second(s), 18 queries .
