When not using an auto-darkening lens.
发表于 2021-10-24 15:51:30 | 显示全部楼层 |阅读模式
Sorry if this is a stupid question, but I assume most of you like myself are using an auto-darkening lens.  For those of you that use the fixed shade lenses, probably mostly old-schoolers, how do you know where to strike the arc with out seeing?  I know practice and experience is the solution but is there a technique or tips that could help speed up the process of getting better?
Reply:welcome  back billy boy, its called "coordination".      im not claimioming to be the most cooordinated, but conventional lense is all i use.
Reply:Mastering the hood flip is the key. If possible I will steady the rod or gun over my off hand when I light up and then pull it away.
GMT+8, 2025-12-19 07:02 , Processed in 0.097845 second(s), 18 queries .
