TD CUTMASTER 38 - component identification
发表于 2021-10-23 15:52:19 | 显示全部楼层 |阅读模式
Hi all,Can any one identify the diode below D51 on a cutmaster 38? I was hoping someone should know this info or have a machine available to check it out.
I picked a cutmaster 38 a little while ago and couldn’t get the pilot arc to start so it’s not cutting at the moment, I swapped out the torch consumables but had no luck.Upon opening the machine I can see that it has had an issue on the board and blown one of the IGBTs and a diode so I’m planning to replace and give it another try.
For any one with a similar issue the IGBT is an APT 60GT60BR
GMT+8, 2025-12-19 13:48 , Processed in 0.114501 second(s), 18 queries .
