查看: 13|回复: 0
2110 Rods Any Information?
发表于 2021-10-22 15:52:03 | 显示全部楼层 |阅读模式
Hi.  I was taking a load of firewood to an old fellow.  He was tidying up his garage and had found a full box of welding rods which he gave me.  They are  2110 rods.  and they are  3/16  which is  just about too  big for  my  200 amp  inverter welder  They  look far bigger as they have such a heavy flux on them.  The weld  has a bronze  coloured look  so I wondered if they are a  rod  for cast  maybe.  I couldn't find any information  on the  internet  So wondered if anyone had ever heard of them     Thanks
Reply:FeaturesCan be applied AC or DC reverse polarity Weldability is excellent with low spatterSTOODY® 2110 is a solid core electrode designed for build-up of austenitic manganese parts subject to high impact loadingModified high chromium - high manganese steel that combines toughness and wear resistanceNo limitation on deposit thicknessSTOODY® 2110 is not recommended for cast ironCan be used on carbon steel or manganese steel base metalSMAW ProcessGood abrasive resistanceExcellent impact resistance
GMT+8, 2025-12-19 13:16 , Processed in 0.094233 second(s), 19 queries .
