What is this switch(?) called?
发表于 2021-10-21 15:51:29 | 显示全部楼层 |阅读模式
Was replacing the nuts on this "switch" and one of the studs broke off. Can someone tell me what it's called so I can get a replacement.It's off a Esab Migmaster 150.Thanks
Reply:A "terminal block". Thank you for your help.
Reply:And back off on the torque a little.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Is that the terminals where you switch polarity?
Reply:It looks like a SHUNT to me.  I really don't know for sure and without seeing the rest of the circuit or schematic, Im guessing. It is deffinitly shuntting a connection.  A SHUNT is another word for short but a SHUNT is used for metering current.
GMT+8, 2025-12-19 13:15 , Processed in 0.108661 second(s), 18 queries .
