Mig power and feed settings
发表于 2021-10-19 15:51:22 | 显示全部楼层 |阅读模式
I have a Hobart 130.   It has a chart which provide setting for different thickness and for the type of wire.   I have an ArCO2 bottle.   I have noticed that when I use the recommended settings, the feed rate is too and and the wire start to pile up in the puddle.  So I adjust it down and then things work out.Here is one I don't quite know how to adjust for.   Lets say I have 1/4 inches thick piece of steel angel and I want to weld an 1/8 inch piece of flat stock to it.    Is there a rule of thumb on how to adjust voltage and wire feed when I have a difference in the thickness of stock?  Is it just a matter of trial and error on some scrap to figure it out?Last edited by smokey9701; 16 Hours Ago at 11:18 AM.
Reply:The door charts just get you close, you are right to adjust as needed.For thick to thin, set for the thicker piece, then hold more arc/bead on the thicker piece.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-19 13:16 , Processed in 0.095084 second(s), 18 queries .
