weight of handrail
发表于 2021-10-18 15:51:29 | 显示全部楼层 |阅读模式
Just a quick question for all of you rail makers.  I made a rail out of all solid stock.  I weighed it and comes in around 55Lbs.  My question is do you think if I core drill 2" holes 4" deep will it be sturdy enough.  End posts are 1 " square.  The steps are only about 3 years old.
Reply:If its concrete no dramas .Also the 4" is in concrete not including tiles etcA good guess is better than a bad measurement
Reply:As Brett said, if in good concrete or good brick (not crumbling or coming apart) you will be fine depending on anchor material. I use Quik-Rock.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Thank you for the replies.  Yes, it will be in 4" of concrete, no tile.  SweetMK, I think you have an excellent suggestion.
Reply:Also, it would be better if you can tie one end to a wall or if you put a small return section at 90*. A single straight section will have some wiggle if just anchored in the holes.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:SweetMK brings up a good point I didn't mention.Deforming the leg so that it does not come up vertically. A much greater concern in things like polished SS tube than solid square stock , but still a step.Does not have to be any thing too radical , but options depending on type of leg include.A simple welded stip/ strips.Hitting tube with a hammer at bottom.Drilling a hole Drilling a hole and putting in a boltLocalised bending of legA good guess is better than a bad measurement
Reply:Đăng ký BIDV SmartBanking tại nhÃ*- Nháº*n quÃ* 300.000 đồng- Nháº*n ngay combo voucher 200.000 đồng, gồm 2 mã giảm giá VNPAY-QR vÃ* 2 mã giảm giá Vnshop, trị giá 50.000 đồng/mã.- HoÃ*n ngay 50% (tối đa 50.000 đồng) giá trị nạp tiền điện thoại lần đầu trên ứng dụng.- Nháº*n thêm 50.000 đồng tiền mặt khi đăng ký bằng định danh trá»±c tuyến eKYC vÃ* thá»±c hiện một giao dịch tÃ*i chÃ*nhChi tiết chương trình tại: https://www.bidv.com.vn/smartbanking
GMT+8, 2025-12-19 13:14 , Processed in 0.095240 second(s), 18 queries .
