Tig hose broke
发表于 2021-10-18 15:51:29 | 显示全部楼层 |阅读模式
My mini chinese tig gas hose cracked.its the hose to the torch. The fitting is a compression type so i assume the pressure is high. Can this be repaired?
Reply:Typical shielding gas pressures are around 50psi, so not that high pressure.   Braid-reinforced vinyl hose (thick wall) of the same size will suffice.
Reply:YOu also may want to check the regulator to be sure the pressure is not creeping up higher then is should be.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
GMT+8, 2025-12-19 13:14 , Processed in 0.092411 second(s), 18 queries .
